Server Products
4761 Discussions
S1200SPLR + Xeon E3 1246 v6 issue
ARoma5
Should S1200SPLR board work with Xeon E3 1246 v6 without any BIOS update?
Just bought this mb and cpu (both brand new), after assembly, all i can see is below error code:
Short video of diagnostic LED below:
https://photos.app.goo.gl/zCQu11ieNJAhoBAEA https://photos.app.goo.gl/zCQu11ieNJAhoBAEA
Unfortunately dont have any other compatible processor, is there anything i can do ? or just send it back to shop?
Hi anaxagore78,
Based on the error code I have checked at our website and the processor does not appear to be compatible with that specific motherboard, this can be verified in the following links, under compatible products:
https://ark.intel.com/products/97950/Intel-Server-Board-S1200SPLR
https://ark.intel.com/products/80916/Intel-Xeon-Processor-E3-1246-v3-8M-Cache-3_50-GHz
Let me know if there is something else.
Eduardo_B
ARoma5
Hi
I'm sorry, my fault Xeon E3 1246 v6 doesn't even exists, i misspelled processor details - (i've got E3 1246 v3 in other machine),
correct processor name- Xeon E3 1275 v6,
so that's configuration i've got:
Xeon E3 1275 v6 +S1200SPLR.
When machine is off, there are 2 green LED lighten up 3 and 0,
after power-on there is no video, there are 2 orange LEDs lighten up 7 and 5, all green LEDs are off
Hi anaxagore78,
In this case based on the LEDs and information you shared it will be a good idea to test it out with another processor but since you do not have another one I will suggest you to return it. The LEDs are indicating an issue with the processor.
Eduardo_B
Hi anaxagore78,
Please let me know if there is anything else you may need assistance with.
Eduardo_B
ARoma5
No thank u,
service said it's memory issue.
Hello, anaxagore78,
I am glad to know you were able to figure out what the problem was. Do not hesitate if we can help you with anything else.
Miguel C.
ARoma5
Actually,
could tell me which memory modules are compatible with S1200SPLR ?
I was told that this is proper module -https://www.samsung.com/semiconductor/dram/module/M391A2K43BB1-CRC/ M391A2K43BB1-CRC | Samsung Semiconductor Global Website
but after failure with already bought modules I'd like to double check this time.
Hello, anaxagore78,
Sure, I can provide you the tested memories with the Intel® Xeon® Processor E3-1275 v6 and Intel® Server motherboard S1200SPLR.
The Samsung M391A2K43BB1-CRC is included in the tested list of memories. Bear in mind the memory controller is into the processor now and we always need to review the processor specifications.
I am sending the full list of tested memories plus processor specs. Additionally, you can find all the tested devices with the board at https://serverconfigurator.intel.com/exodus/page?eventType=1&targetPageId=1201&defaultFlag=1
Let me know if I can help you with anything else.
Miguel C.
