Hi I just reveived the s1200bts and it will not boot. These thing are connected to it:
- 2x power cable
- front panel
- processor E3-1230 + box cooler
- 1x 2GB ram module
- nothing else
The board will not boot and shuts itself down after a while. No beeps, diagnostic led light up like this: 0x22h (0010 0010 = bit1 & bit5 on, others off) which is NOT specified in documentation.
what has been also tried without success (LED still show 0x22h):
- pci-e VGA
- connect SATA disks
- connect intrusion detection
- change RAMs
- take out RAMs = 3 beeps
Could someone please help me out?
Check if the RAM is compatible with the motherboard+ processor combination.
Try different power supply.
Try different processor.
I recommend a Clear CMOS after each change.
If the system doesn't boot with only MB + Proc + RAM + Pwr, then it is most likely the motherboard.
