Server Products
4778 Discussions
S2600CP and RAM
TFolk
Just wondering if i am missing something.
I purchased a ACT16GHR72U4J1600S which is stated as being compatible here: http://www.cmtlabs.com/2012/mbTestSummary.asp?bNav=True&outside=False&sTestNum=018403 CMTL > Search > Tested Motherboard > Results
However, when i insert the ram and boot the computer, i get the fatal 3 beeps.
I know there is a chance it could be bad but i do not believe it and unfortunately do not have another computer to check it with.
Is there anything i needed to do in BIOS to support it?
Current config:
(2) E5-2680v2
(2) Kingston KVR13E9/4I 4GB
Hello Taylor,
The 3 long beep indicates that you are having a memory error.
As first troubleshooting step test one memory module at the time and check if you still get the 3 long beeps. Also test each memory slot individually.
If the problem continues, please test different memory on your system, click https://serverconfigurator.intel.com/exalt/MyPartsServlet?iMethodID=4&dataset=IntelTHOL&basefilters=column1_IN_S2600CP2_AND_column3_IN_None&bypass=y here for the list of compatible memory.
You can also test your old memory module and check if the problem continues.
Sergio S.
Hello Taylor,
We are following up your question and we would like to know if you need further assistance. In case you need more help, please feel free to contact us back.
Sergio S.
Hello Taylor,
Sergio S.
