Server Products
4778 Discussions
S2600CP problem! please help me.
AIsac
Motherboard S2600CP when connecting the power supply to the motherboard will flash all LEDs on the motherboard. What it is?
Please provide a more detailed description of the issue in order to assist you further with accurate troubleshooting.
AIsac
I threw a link to photos and videos with the problem
Here are our recommendations for this issue:
- Take the board outside the chassis and try it on a minimal configuration (processor, memory, monitor, keyboard).
- Test the system without memory installed looking for beep codes.
- Test each processor on the cpu socket # 1 to narrow the issue.
If the system still unresponsive after these troubleshooting steps, we recommend replacing the board under warranty.
