Hi everyone, I am running an Intel S2600CP2J motherboard in a DP config, and I have two separate SSDs attached to SATA ports 0 and 1. I would like to set up a multi boot setup with macOS Sierra on one drive and Windows 10 x64 on the other.
But, I am struggling immensely with getting the motherboard to recognise the two USB thumb drives I've set up as boot disks. For the Windows USB I've set it up as:
- FAT32
- Master Boot Record
- Used macOS diskutil to set up a Windows 10 ISO on the drive.
For the macOS Sierra boot disk:
- Mac OS Extended Journal
- Apple GUID Partition Map
- Unibeast to set up EFI installer for macOS Sierra installer
- Added Multibeast to the drive
I'm not quite sure what the issue is, but I simply cannot boot from either USB disk, not as a boot option nor from the EFI Shell.
Any assistance would be highly appreciated.
Cheers
