Server Products
4762 Discussions
S2600CW can not find POST Progress Code LED when try boot with XEON E5-2670 V3 CONFIDENTIAL (QFSA)
ALexo
  1. Power ON
  2. wait until three beep and get LED POST Progress Code -Screenshot_2018-12-19-10-05-23-740_com.viber.voip.jpg
  3. look in it pdf to find what it meen three beep - https://www.intel.com/content/dam/support/us/en/documents/server-products/server-boards/S2600CW_TPS_Rev2_4.pdf.pdf
  4. at page 189 in table 97 get - System halted because a fatal error related to the memory was detected. AND See Table 93. to find POST Progress Code LED
  5. My LED cod (from photo) is (00010100)2 = (14)16 = 14h - isin't it?
  6. and now I try and can not find it code in table 93.
  7. I try find it in other pdf file with chassis description (table 6, 7 and 8 ) - https://www.intel.com/content/dam/support/us/en/documents/server-products/server-boards/P4000_CW_ST_ServiceGuide_Rev2.0.pdf
  8. No Luck.
  9. Upload video with slower timline with all booting progress - https://photos.app.goo.gl/zoD9MZu1XXeXvhbs6
  10. Upload video with normal timline with all booting progress -https://photos.app.goo.gl/7BHC8S6g2WPeXtbJ8
  11. Ask a help to understand it LED POST Progress Code and how I can boot it Server.
  12. And yes, DDR4 memory was switched to other server and boot up it with no problem. - IMG_20181219_135818.jpg
JoseH_Intel
Hello ALexo, Thank you for joining the community. Looks like you have an engineering sample processor. These processors are given to certain customers usually earlier to an official product release for testing purposes only. Unfortunately they don't have any kind of support because of their nature since most likely they will show bug errors that are supposed to be corrected in the final releases. The alternate path here will be to test if the board works correctly. You could try to boot the system with no processor and expect the processor error to happen letting you know the board is possibly fine. You could try to boot the system with a good known processor in case you have it too. Hope this helps Jose A. Intel Customer Support Technician Under Contract to Intel Corporation
JoseH_Intel
Hello ALexo, Do you have any updates, questions or comments in regards to this issue? Please do not hesitate to contact us back. If you consider the issue to be completed please let us know so we can proceed to mark this thread as resolved. Regards Jose A. Intel Customer Support Technician Under Contract to Intel Corporation
ALexo
Thank you for answer, but in my case I asked help me, what i must do with my hardware and yes, I solved my problem myself.
I just changed my DDR4 memory to other with 2133 Mhz and ECC REG and all start work right
I tried many different kinds of it memmory with 2400, 2666 with ECC and witout and had problem with boot, I think you must make some update bios to teach it motherboard understand mach more kinds of memory
for example when I connect 7 different kinds of memory bios can see only 3 but when I load Windows in test programs like CPU-Z AIDA64 or HWinfo  I can see all of them, But if I put out all memory with 2133 Mhz Motherboard did not want boot
I was connecting memory with ECC REG 2400 Mhz and 2666 Mhz and it do not boot I think it trouble is in bios of it motherboard. Processor work correctly Thank you.
JoseH_Intel
Hello ALexo, Good to hear that you got the issue resolved. We will take your feedback into consideration. We will proceed to mark this thread as resolved. If you have further issues or questions just go ahead and create a new topic. Jose A. Intel Customer Support Technician Under Contract to Intel Corporation
