Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4655 Discussions
S2600CW2 in a P4304XXMFEN2
RSump1
New Contributor III
I have a S2600CW2 in a P4304XXMFEN2. If I want to convert this to redundant power supplies, will there be any issues in doing so? Will I need to re-run the firmware/bios update?
Ray
JoseH_Intel
Hello RSump1,
Welcome back to the Intel community
So pretty much you want to convert a P4304XXMFEN2 chassis into a P4304XXMUXX. According to the Technical Product Specification document it seems like both chassis come with the same Power Distribution Board. If this is the case then it might be possible to remove the fixed PSU and replace it with both redundant PSU. You will need the following part numbers:
PSU cage assembly: FUPCRPSCAGE
Power Distribution Board: FUPPDBHC (Make sure you have the high current model)
Either one of these PSU models
1200W PSU: FXX1200PCRPS
1600W PSU: FXX1600PCRPS
BIOS wise it is always recommended to be on the latest available and make sure you update both FRU and SDR after installing the redundant PSUs so both will be recognized by the BMC
Let me know if you have further questions
Jose A.
Intel Customer Support
For firmware updates and troubleshooting tips, visit:
https://intel.com/support/serverbios
RSump1
New Contributor III
Hello Jose, Thank you for your input, will I have any issues going to a redundant power but only have 2 case fans? I know the P4304XXMUXX has a redundant power supply with 5 hotswap fans. Thanks
JoseH_Intel
Hello RSump1,
That is an interesting question. It is correct that P4304XXMUXX chassis come with 5 redundant hot swappable fans. I could not find any specific info other than 2 food notes on the TPS. I will research on this even when this conversions are not that common.
Jose A.
Emeth_O_Intel
Hello RSump1,
I am contacting you on behave of Jose A.
We would like to inform you that in this particular case, you need to make sure when running the FUP for the FRU/SDR portion. Also, you need to select option 3 to "update both FRU and SDR" when it detects the chassis you would need to select "Other" and program each header individually.
For Chassis intrusion, you would need to select "No".
Please let me know if this information helps you in order to proceed with the next step.
Emeth O.
Intel Server Specialist.
RSump1
New Contributor III
Good morning, Even though I am using an Intel chassis, I need to say "no chassis intrusion"?
SergioS_Intel
Hello RSump1,
The autoconfiguration mode won't work since this would be a custom configuration. Please bear in mind that this is not a validated configuration as we don't have a native solution that comes with redundant PSUs + 2 fixed fan arrangement.
Fans could run at full speed even after performing the update.
Finally, to answer your question, you will need to select "No".
Sergio S.
JoseH_Intel
Hello RSump1,
We will proceed to mark this thread as resolved. If you have further issues or questions just go ahead and create a new topic.
Jose A.
JoseH_Intel
Hello RSump1,
We will proceed to mark this ticket as resolved. If you have further issues or questions just go ahead and create a new support interaction. All the information will remain in our databases for future reference.
Jose A.
