Community
cancel
Showing results for
Search instead for
Did you mean:
S2600CW2R has USB items listed as "- Eject ACPI Module Device".
Hi, if I select the eject usb icon, it displays 2 items, both are "- Eject ACPI Module Device".
What is it & how do I get rid of this?
Server Specs:
S2600CW2R with latest fw: 1.01.0015;1.41.9579
2x E5-2609v3 cpu
4x 8GB DDR4-2133 Reg Ecc
LSI 9260-4i with latest fw: 0239 & driver 6.709.12.00
4x 1TB Samsung 850 EVO Raid 6
SVR STD 2012 R2
Software:
Intel Inf 10.1.2.10
Emulex display driver 4.01.01.005
Intel Lan 20.3
Intel Active System Console 7.0.34
Megaraid Manager 15.08.01.02
Thanks!
Community Manager
After testing with a clean installation of the Operating System using Windows 2012 R2, we are not able to reproduce the issue you are experiencing reason why we recommend making sure you are installing all the proper software and drivers for the other hardware components.
I've built a 2nd Server & experienced the same thing. It's not really an issue but an annoyance.
It's been tested & shipped to our client.
The next Server build I get I'll test it without the LSI card 1st & perhaps try an older firmware as well...
