Server Products
4551 Discussions
S2600GZ with more than 256GB of memory
СКаще
Hi!
We are trying to get R2312GZ4GC4 server platform working with more than 256GB of RAM
Prod. code: R2312GZ4GC4
Serial: FHBF244003B
TA. NO: G63765-002
Mainboard PBA: G11481-352
Mainboard serial: QSGR23100049
We have latest firmware installed from this download - http://downloadmirror.intel.com/22512/eng/S2600GZ_GL_EFI_BIOS01060002_ME20107112_BMC1174207_FRUSDR109.zip http://downloadmirror.intel.com/22512/eng/S2600GZ_GL_EFI_BIOS01060002_ME20107112_BMC1174207_FRUSDR109.zip
Dual Xeon E5-2680 installed.
Memory modules - 32GB Hynix HMT84GR7MMR4A-H9D3
Maximum working amount of memory - 256GB (8 DIMMs installed in blue memory slots)
If we add more DIMMs - system does not start at all or start with some memory slots marked as fault by LEDs on the board (depends on combination of used slots)
I can't understand the cause of the problem. Server configurator tool list this memory modules as supported and allow to configure up to 24 modules for this platform.
We have 2 identical server platforms on hands and situation with memory idetical on both of them.
Edward_Z_Intel
As per https://www.skhynix.com/products/computing/view.jsp?info.ramKind=20&info.serialNo=HMT84GR7MMR4A https://www.skhynix.com/products/computing/view.jsp?info.ramKind=20&info.serialNo=HMT84GR7MMR4A, your DIMM is quad-rank. S2600GZ supports up to 8 ranks per memory channel, so in your case two DIMMs per channel.
For more details, refer to the board http://www.intel.com/support/motherboards/server/sb/CS-033134.htm Technical Product Specification (TPS), section 3.2.4.
СКаще
S2600GZ - 24 DIMM slots – 3 DIMMs/Channel – 4 memory channels per processor
8 memory channels total with dual CPU configuration
we have only one DIMM per channel (all DIMMs in blue slots) - this is 4 ranks per channel
at least it must work with 2 quad-rank DIMMs per channel if 8 ranks per channel is limitation
Edward_Z_Intel
Ahh sorry for the misunderstanding - I thought you were talking about each processor...
Have you tried to install 8 DIMMs on one processor and see if it works?
СКаще
Yes we try to remove all memory modules from channels E-H
System does not start correctly with more than 4 modules in this configuration
Also we try to start system using only channels A & B - system start correctly only with 2 DIMMs installed in A1 & B1.
If modules installed in A1, A2, A3, B1 then system starts, but modules A1, A2, A3 marked as fault by LEDs and BIOS displays only 32GB of RAM (B1 module).
If modules installed in A1, A2, B1, B2 then system does not start.
Edward_Z_Intel
So it confirms that the issue is not about total capacity, but each memory channel accepts only one DIMM... Not sure if it's related to the DIMM using DDP (Dual Die Packate) and having "8 internal banks"...
Daniel_O_Intel
You can also try going into the BIOS and changing
Advanced > System Acoustic and Performance Configuration > DCLTT
See if that helps the boot any.
СКаще
