Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
S2600TPR Questions
Jump to solution
I am looking at using the S2600TPR board for a project and I have a few questions:
1. Can all 4 riser slots be used as a PCIe expansion slot or have a riser card to make a PCIe expansion slot?
2. Can the mezzanine port be converted to a PCIe expansion slot?
3. Does the Intel S2600TPR board support VMware ESXi?
Accepted Solutions
Highlighted
Community Manager
Re: S2600TPR Questions
Jump to solution
Hello macrules34,
Answering your questions:
There are only 2 PCIe slots on this board allowing you to use only 2 riser cards. The riser cards are pass through only to the PCIe slot on the board.
The mezzanine port (I/O module carrier) supports both a SATA M.2 storage device and a 8x PCIe 3.0 devices. You can check the https://www.intel.com/content/dam/support/us/en/documents/server-products/H35763-003_S2600TP_HNS2600... Technical Product Specification document on page 18
The S2600TP family board does support VMware ESXi 6.5 at a basic installation and compatibility level. You can check this info on this https://www.intel.com/content/www/us/en/support/server-products/server-boards/000007872.html URL
Hope this helps
Jose H.
Highlighted
Community Manager
Jump to solution
Hello macrules34,
Hope this helps
Jose H.
Highlighted
Jump to solution
Jose,
I would like to use riser slots 1 & 2 for standard PCIe expansion slots what are the part numbers for the riser cards? I couldn't find them in the manual.
Highlighted
Community Manager
Jump to solution
Hello macrules34,
The PCIe riser part number is:
PCI express riser FHW1U16RISER2.
You could get the spare parts number list from the following document: https://www.intel.com/content/dam/support/us/en/documents/server-products/server-boards/S2600TPR_HNS...
Jose H.
Highlighted
Community Manager
Jump to solution
Hello macrules34,
Do you have any updates about this.
Just let me know.
Regards.
Jose H.
Highlighted
Jump to solution
Thats all the questions I have for now. Will post more if I have further questions. Thanks for your help.
Macrules34
Community Manager
Jump to solution
Thanks Macrules34,
I will mark this thread as answered by now.
Jose H.
