Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage; and Intel® Xeon® Processors
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
For the latest information on Intel’s response to the Log4j/Log4Shell vulnerability, please see Intel-SA-00646
4330 Discussions
S2600URBRPR with S5520UR and Matrox G200e Ubuntu driver
Community Manager
Can anyone point me towards a setup or driver for the Matrox G200e on-board (S5520UR) graphics card? I am finding that Ubuntu 11.10 server 64bit is not using the correct driver.
Edward_Z_Intel
No additional video driver is available for Linux. Just use the embedded driver.
Community Manager
The embedded driver is limited to 1024x768 which is too small for some of the windows in Ubuntu . There are no alternatives? other than adding in a pci-e card of course.
What makes things worse is that a identical server running MS Windows server 2008 r2 has drivers and does give me higher resolutions...
