Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage; and Intel® Xeon® Processors
4504 Discussions
S2600WF PCIe Fatal error
grubjack
Can't install OS from ISO - the server constantly reloads itself during installation.
In the event log:
21 Mon May 16 17:56:08 2022 PCIe Fatal Error SMI Handler Critical Critical Interrupt Surprise Link Down Error Bus: 174 Device: 0 Function: 0 - OEM - Asserted
19 Mon May 16 17:50:41 2022 PCIe Fatal Error SMI Handler Critical Critical Interrupt Surprise Link Down Error Bus: 174 Device: 0 Function: 0 - OEM - Asserted
17 Mon May 16 17:43:49 2022 PCIe Fatal Error SMI Handler Critical Critical Interrupt Surprise Link Down Error Bus: 174 Device: 0 Function: 0 - OEM - Asserted
Checked the RAM by the memtest and it's OK.
How to define the cause?
JoseH_Intel
Hello grubjack,
Thank you for joining the Intel community
Does the system reboots when on BIOS or in UEFI shell? Could you try to update the BIOS firmware to the latest: Intel® Server Board S2600WF Family BIOS and Firmware Update Package for UEFI
If not working you can attempt the BIOS recovery procedure detailed here BIOS Recovery Procedure for Current Intel® Server Boards
Jose A.
grubjack
Updated BIOS to the latest version
Host is currently ON
Installed
Yes
Sun Mar 20 00:53:39 2022
SE5C620.86B.02.01.0015.032120220358
2.88.6999d21a
System reboots when I install OS from ISO in legacy boot. ( that's the custom image and I don't see it in UEFI mode )
JoseH_Intel
Hello grubjack,
Thank you for the update.
Could you tell the OS you are attempting to install? Is it possible to try the OS installation in UEFI mode?
Also could you share the memory DIMMs brand and model so we can confirm if validated?
Jose A.
JoseH_Intel
Hello grubjack,
I am just following up to double check if you were able to gather the requested information. Otherwise let us know if you require more time to accomplish this. I will try to reach you on next Tuesday 24th. After that the thread will be archived automatically.
Jose A.
JoseH_Intel
Hello grubjack,
We will proceed to mark this thread as closed. If you have further issues or questions just go ahead and submit a new topic.
Jose A.
