Can't install OS from ISO - the server constantly reloads itself during installation.
In the event log:
21 | Mon May 16 17:56:08 2022 | PCIe Fatal Error | SMI Handler | Critical | Critical Interrupt | Surprise Link Down Error Bus: 174 Device: 0 Function: 0 - OEM - Asserted |
19 | Mon May 16 17:50:41 2022 | PCIe Fatal Error | SMI Handler | Critical | Critical Interrupt | Surprise Link Down Error Bus: 174 Device: 0 Function: 0 - OEM - Asserted |
17 | Mon May 16 17:43:49 2022 | PCIe Fatal Error | SMI Handler | Critical | Critical Interrupt | Surprise Link Down Error Bus: 174 Device: 0 Function: 0 - OEM - Asserted |
Checked the RAM by the memtest and it's OK.
How to define the cause?
Hello grubjack,
Thank you for joining the Intel community
Does the system reboots when on BIOS or in UEFI shell? Could you try to update the BIOS firmware to the latest: Intel® Server Board S2600WF Family BIOS and Firmware Update Package for UEFI
If not working you can attempt the BIOS recovery procedure detailed here BIOS Recovery Procedure for Current Intel® Server Boards
Jose A.
For firmware updates and troubleshooting tips, visit:
https://intel.com/support/serverbios
Updated BIOS to the latest version
Host is currently ON | |
Installed | |
Yes | |
Sun Mar 20 00:53:39 2022 | |
SE5C620.86B.02.01.0015.032120220358 | |
2.88.6999d21a |
System reboots when I install OS from ISO in legacy boot. ( that's the custom image and I don't see it in UEFI mode )
Hello grubjack,
Thank you for the update.
Could you tell the OS you are attempting to install? Is it possible to try the OS installation in UEFI mode?
Also could you share the memory DIMMs brand and model so we can confirm if validated?
Jose A.
Hello grubjack,
I am just following up to double check if you were able to gather the requested information. Otherwise let us know if you require more time to accomplish this. I will try to reach you on next Tuesday 24th. After that the thread will be archived automatically.
Jose A.
Hello grubjack,
We will proceed to mark this thread as closed. If you have further issues or questions just go ahead and submit a new topic.
Jose A.
