- System BIOS - 02.01.0014
- ME Firmware - 04.01.04.505
- BMC Firmware - 2.86.2da97d3f
- FRUSDR - 2.02
Running "sudo ipmitool raw 0x30 0xb1 0x00 0x80 0x00" to disable ssh is not working on this version of the BMC firmware. The previous update that contained BMC version 2.48.ce3e3bd2 worked fine.
This is reported by our customer and I'm not able to test this until the new year but is anyone aware of any changes in the latest BMC that would affect this command running?
I believe the customer to be running a custom linux based on Ubuntu 18.04
Many Thanks
Hello SWRIG,
I hope you are doing great, thank you for your patience, can you please try using the following command:
- [root@localhost ~]# sudo ipmitool -I lanplus -H 192.168.1.59 -U root -P Intel@123 -C 17 raw 0x30 0xb1 0x00 0x40 0x00
Please let me know the outcome. I will wait for your response, if I do not hear from you I will follow up in 2 business days.
Paul R.
For firmware updates and troubleshooting tips, visit:
https://intel.com/support/serverbios
Hello SWRIG,
Thank you for joining the community. I understand that the command to disable ssh is not working on this version of the BMC firmware for your customer.
Please allow me to investigate further and I will get back to you.
Paul R.
Hello SWRIG,
Paul R.
Hello SWRIG,
I hope you are doing great, we would like to know if the command worked as expected.
We will be waiting for your reply.
Paul R.
Hi Paul
Sorry for the delay, only just had a reply back from our customer.
They tell us that command worked perfectly.
I was wondering where any of these raw commands are documented; I've not been able to find anything other than as an answer on these forums, it would also be useful to know what changed in the BMC firmware between the two versions that could have changed the way this worked.
Many thanks for your help
Simon
Hello SWRIG,
Thank you very much for the update, I am glad to hear that, let me investigate further on what changed on the BMC that affected the previous command and how this will be documented publicly. I will get back to you as soon as possible.
Paul R.
Hello SWRIG,
I hope you are doing great, thank you for your patience, the raw commands and documentation can be found in RDC document 598340 (Purley BMC EPS).
Here is the website:
Please let us know if there is anything else that we can do for you.
Paul R.
Hello SWRIG,
We would like to know if you need further assistance. In case you do, we would highly appreciate if you would let us know.
Paul R.
No, Thanks for all your help, our customer is now happy they can do what they need.
Hello SWRIG,
I hope you are doing fantastic, I am glad to hear that, we will proceed to mark this thread as close, please do not hesitate to contact us back if further help is needed.
Paul R.
