Server Products
4776 Discussions
S2600WTT / ESXi 6.7
SDiem
Hi
I installed on a S2600WTTR (Bios: SE5C610.86B.01.01.0027.071020182329 / CPU Intel(R) Xeon(R) CPU E5-2660 v4 @ 2.00GHz)
ESXi 6.7. (6.7.0 (Build 10176752))
Now i see that some Sensors are unknown.
But on the VMWare Compatibility Guid the System shod be ESXi 6.7 compliant:
Intel S2600WTT Intel Xeon E5-2600-v4 Series ESXi 6.7,ESXi 6.5 U2,ESXi 6.5 U1,ESXi 6.5,ESXi 6.0 U3,ESXi 6.0 U2,ESXi 6.0 U1
https://www.vmware.com/resources/compatibility/pdf/vi_systems_guide.pdf https://www.vmware.com/resources/compatibility/pdf/vi_systems_guide.pdf
Have i missed something ?
Hello Siliconbrain,
Hope you are doing fine.
I order to better assist you can you share the Sysinfo logs from the current server?
Charlie_Intel
SDiem
Hi
Here is the Syslog
Thanks for your support.
Hello Siliconbrain,
Is there any fan ramping or processor overheating?
We checked the system logs and there are no errors events or critical errors in the server, seems to be working smoothly.
Did you try to clear the SEL, clear the C/MOS in the BIOS and then the same to the OS in order to see if that updates the sensors?
Charlie_Intel
SDiem
Hi Charlie_Intel
I have installed ESXi 6.5 and all Sensors are fine!! Also alle Sensors in the BMC Health Status are green and OK.
So for me it looks like the Board is'nt fully supported under ESXi 6.7.
I would just like to know if this Board is fully ESXi 6.7 Compliant or not!
Displaying Board Area
Board Information Area (Version 1,Length 80)
Unicode Country Base : 00h
Manufacturing Time(mins) : Thu Jan 4 04:40:00 2018
Manufacturing Name(ASCII) : Intel Corporation
Product Name(ASCII) : S2600WTTR
Serial Number(ASCII) : BQWL75250123
Part Number(ASCII) : G92187-372
Mftr FRU File ID(ASCII) : FRU Ver 1.00
Displaying Product Area
Product Information Area (Version 1,Length 104)
Manufacturer Name(ASCII) : Intel Corporation
Product Version(ASCII) : R2224WTTYSR
Part Number(ASCII) : J11492-010
Serial Number ID(ASCII) : BQWD80590624
Asset Tag(ASCII) : ....................
Thanks in advance
Hello Siliconbrain,
Well as the system logs were fine it should be working smoothly using ESXi 6.7, in regards to the compatibility question, yes, the sensor reading could be a software issue but it is related directly to Vmware, so I recommend you to open a case with them in order to have an accurate response and maybe an ETA from the latest O.S update to fix the issue.
Charlie_Intel
SDiem
Hi
Since i updated to the newest Build 6.7.0 Update 1 (Build 10302608) it just shows 1 Sensors as unknown.
Hello Siliconbrain,
So with the update, the issue or unknown sensor was reduced to 1?
Just the "Management Controller Firmware 2 NM" right?
Charlie_Intel
SDiem
Hi Charlie_Intel
Yes, with the newest Version ESXi-6.7.0-20181002001/ Build 10302608 (2018-10-16 Update 1) just one Sensor: "Management Controller Firmware 2 NM" is unknown.
Hello Siliconbrain,
Perfect, it is a confirmation that the O.S updates are fixing the issue with each of their updates, and it is not a board issue, next new build should fix "Management Controller Firmware 2 NM" if it is necessary for the system.
Charlie_Intel
Hello Siliconbrain,
We are wondering if you have further questions?
Charlie_Intel
Hello Siliconbrain,
We are wondering if you need further assistance?
Charlie_Intel
SDiem
Hi Charlie_Intel
Thank you all fine. No further assistance needed at the moment.
Kind regards
Siliconbrain
