Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4860 Discussions
S2600WTTR - DIMM Thrm Mrgn unknown --> BMC Health
BBosb
We have two identical Intel servers with S2600WTTR serverboards with same hardware configuration.
Both servers recently have a unknown status in Server Health.
Error:
Name - Status - Health - Reading
DIMM Thrm Mrgn 2 - Normal - Unknown - Not Available
Strange thing as well is that one server has 74 sensors and the other has 82.
One server also gives this error on DIMM Thrm Mrgn 4 where the one with less sensors does not report that sensor at all.
I can’t find much about the errors; found a topic here where support took over so here I am posting :).
Hope someone can help!
BMC FW Build Time : 2018-06-07 11:48:53
BIOS ID : SE5C610.86B.01.01.0027.071020182329
BMC FW Rev : 1.53.11210
Boot FW Rev : 1.07
SDR Package Version : SDR Package 1.17
Mgmt Engine (ME) FW Rev : 03.01.03.050
Thanks in advance!
JoseH_Intel
Hello BBosb,
Thank you for joining the community
You say this issue has appeared recently. Were both servers working fine before? When did this issue started? Have you performed any hardware or firmware changes recently?
Could you please attach the OEM and part number for the memory DIMMs so we can check in our records?
Besides that please attach a sysinfo log
Also there is an updated version of the BIOS v0028
We will look forward for you updates
Jose A.
A Contingent Worker at Intel
BBosb
Hi Jose,
Thanks for the quick reply!
According to manual server
checks we perform it happened before so its been over two months with this
'error'. No hardware changes are done in the meantime. Also, no noticeable
problems running the server. When I
look through the documents of the check I see it also happened in the past but
was gone the next check.. (Maybe a simple reboot ‘fix’ this problem?)
Last time software/bios/firmware
round was when we installed Bios 0027. That must be some time ago; I need to check when this
exactly happened if that information is needed – during that we also update HBA
and NIC firmware..
These are storage servers which don’t
have a CLI or Shell so I can’t run sysinfo at this time.
We need to plan some downtime for this maintenance to do this is EFI.
We have six other ESX host which are running same
board with slightly other hardware configuration; these are running Bios 0028
but as far as we know these never had this error on BMC.
The two storage servers are running:
2x CPU E5-2609 v3 – ESX server have: CPU E5-2697A v4
4x Samsung M393A4K40BB1-CRC (32GB each, slot A1, B1, E1, F1) – The ESX host have these same modules, only 12 of them instead.
HBA: LSI SAS3008 - SAS9300-8E - 12Gbit – (not in ESX)
NIC: Mellanox ConnectX4 – (same)
I will try to do some maintenance and arrange a log file ASAP.
But maybe you can do something already with above information.
Thanks in advance!
-Bram
JoseH_Intel
Hello BBosb,
Thanks for the updates provided. We will check if any known issue could be found related to this error message. The sysinfo log will definitely help since it will gather a lot more info about the whole status of the server.
We could keep this thread open until your next maintenance window if you think it will happen in the near coming weeks. If you have an ETA will help.
We will get in touch with your soon.
Jose A.
JoseH_Intel
Hello BBosb,
Looking at the error message description in the board TPS, it should specify which processor it refers to with either P1 or P2 at the beginning of the error message, like:
Processor 1 DIMM Aggregate Thermal Margin 2 (P1 DIMM Thrm Mrgn2)
By any chance have you seen this info?
Jose A.
BBosb
Hi Jose,
Unfortunately, the only thing being displayed in the Health status https/bmc is:
‘DIMM Thrm Mrgn 1’
Maybe with other tools I can see different information but BMC/CLP (SSH) does not seem to be able to do much with this sensor, but I could be wrong?
What I can say which might be of some use is that a server reboot does not resolve this error.
What I will do this week or the next is boot remotely in EUFI and start the diagnostics. The only thing that might be an issue is that as far I tried EUFI does not detect a redirected ISO or USB with remote console. The trick I did is to make a ‘floppy image’ which does get detected but that won’t be writeable but I will see how that goes.
Is it wise to also update the BIOS? Do it after diagnostics of before (or both?)..
Thanks in advance.
JoseH_Intel
Hello BBosb,
Please try to take a sysinfo log before and after perform the BIOS update, which by the way is highly recommended.
We will wait for you outcome after performing those steps.
Jose A.
BBosb
I have sent you a PM with topic '0D50P00004XxcDnSAJ' containing download info.
BIOS is upgraded both logs are
attached. We still see the same message in BMC, and the one updated still has
the same amount of sensors (84) where the other servers only has 74..
I will update the BIOS on the
other server as well this weekend because we would like to keep the
configuration the same.
JoseH_Intel
Hello BBosb,
Thanks for the info. We will analyze both logs and will let you know the findings.
Jose A.
BBosb
Update on the BIOS upgrade of the other server which also had less sensors.
The update did fix the number of sensors (they both have 82 now), but also still has both ‘unknown’ sensors. I also send a PM containing logfiles from only after the update.
JoseH_Intel
Hello BBosb,
Thanks for the updates. At least we know that a firmware update fixes the number of sensors.
I was trying to look at your logs but they are password protected. Could you please reattach them.
Jose A.
BBosb
BBosb
The password is provided in the PM I have sent.
JoseH_Intel
Hello BBosb,
I found the password. My mistake.
After looking at the sysinfo log I found no errors. What I saw was some DIMM temperature related READING_UNAVAILABLE messages. Also there are some other DIMMs with negative temperatures values which does not make too much sense either.
Could you please confirm the RAM modules are Samsung M393A4K40BB1-CRC 32 GB?
Jose A.
BBosb
Yes they are all M393A4K40BB1-CRC, as mentioned before, we have 6 other ESX host with same board and 12 of these modules.
They do not display unknown status on DIMM Thrm Mrgn 1/2/3/4 but indeed have negative temperature values as well? Also the 'P1 DTS Therm Mgn' and (P2) values are negative but the rest is normal. but since its 'green' i always figured it just a visual bug that it displays a minus (-) before the value.
JoseH_Intel
Hello BBosb,
I will research further about these negative temperature values on DIMM sensors.
We will let you know soon
Jose A.
BBosb
Any update on this? Do you also want/need the logs of server with same board/memory which do have values on the sensors? Maybe that helps diagnose the problems of missing values?
As said before they also do have negative temperature:
DIMM Thrm Mrgn 1 ** Normal ** OK-59 degrees C
DIMM Thrm Mrgn 2 ** Normal ** OK-58 degrees C
DIMM Thrm Mrgn 3 ** Normal ** OK-55 degrees C
DIMM Thrm Mrgn 4 ** Normal ** OK-59 degrees C
JoseH_Intel
Hello BBosb,
I apologize for the delay. The following is the information provided by our engineering team:
"What you are seeing is normal.
DIMM thermal margin readings are not actual temperature readings of each DIMM installed in the system.
Temperature readings from each DIMM (TSOD) are aggregated into IPMI temp margin sensors for a group of DIMM's. What we see in log is a thermal margin reading for a group of DIMM (not single DIMM).
So in this case, DIMM A1 and DIMM B1 could be in the same group and E1 and F1 in another group.
Margin sensor readings will be negative value since its an offset to critical temperature. Its not actual temperature."
Hope it helps
Jose A.
BBosb
Hi Jose,
No problem.
If the ‘Unknown sensor’ for these sensors are also normal which is main question you can set this topic as answered.
-Bram
JoseH_Intel
Hello BBosb,
Actually it is. The temp margin sensor is the IPMI group of DIMMs, so when it says unknown it refers to the whole aggregate not a single reading. Pretty much this is the way this sensor was designed to work.
Jose A.
