Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4784 Discussions
S3200SHV RAID 5
Is it true that the S3200SHV needs additional hardware or accessories in order to get the onboard RAID-5 working?
Is it possible to make the RAID-5 into a bootable drive so I can load the OS?
Mixed reviews and maybe mis-information here: http://www.newegg.com/Product/Product.aspx?Item=N82E16813121328 http://www.newegg.com/Product/Product.aspx?Item=N82E16813121328
Please clear this up for me.
Thanks!
Edward_Z_Intel
Depends on the OS you're going to install. If you're going to install Windows, then yes you can use the onboard Matrix Storage RAID, and yes you can boot from a RAID 5 volume. Notice that booting from a volume larger than 2TB is not supported.
