Considering this combination, should i use 667 or 800 mhz memory?
Does the board have support for Windows server 2008R2?
Does the SATA-controller have support for staggered spin-up?
altheman wrote:
Considering this combination, should i use 667 or 800 mhz memory? Use faster is better for best results and pick some from this list
http://download.intel.com/support/motherboards/server/s3200sh/sb/s3200sh_memlist_rev_12.pdf http://download.intel.com/support/motherboards/server/s3200sh/sb/s3200sh_memlist_rev_12.pdf
sSpec# CPU SpeedCPU
NumberBus SpeedMfg- Tech SteppingCache SizePackage TypeNoteshttp://ark.intel.com/Product.aspx?spec=SLGU9 SLGU92.80 GHzE63001066 MHz45 nmR02MBLGA7753http://www.intel.com/support/motherboards/server/S3200SH/sb/CS-028293.htm http://www.intel.com/support/motherboards/server/S3200SH/sb/CS-028293.htm
Does the board have support for Windows server 2008R2? yes
Operating SystemType Of TestingNotehttp://www.microsoft.com/ Microsoft* Windows Server* 2008 Enterprise Edition (32-bit)Compatibility & Stresshttp://www.microsoft.com/ Microsoft* Windows Server* 2008 Enterprise Edition for EM64TCompatibility & Stress
http://www.intel.com/support/motherboards/server/sb/CS-030451.htm http://www.intel.com/support/motherboards/server/sb/CS-030451.htm
Does the SATA-controller have support for staggered spin-up? No
Usuful features list http://download.intel.com/support/motherboards/server/s3200sh/sb/e14960009_s3210sh_tps_r1_8.pdf http://download.intel.com/support/motherboards/server/s3200sh/sb/e14960009_s3210sh_tps_r1_8.pdf
