Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage; and Intel® Xeon® Processors
4505 Discussions
S3420GP boards and 3rd part chassis
I have a chassi I want to use for my server.
It is a non-intel chassi not recognized by FRUSDR-update
I read somewhere that if the motherboard does not reconize the chassi it will run with fans on 100% speed all the time.
Can I write my own master.cfg or change IPMI-data some other way to correct this?
Can I connect a thermal sensor to the motherboard connector, and what is the specifcation for such a sensor?
Daniel_O_Intel
There is a document that walks you through modifying the fan control, but it is Intel Confidential. You have to sign an NDA to get access to it.
If you are a channel member, and have already signed one, contact your field representative; otherwise, visit http://www3.intel.com/cd/channel/reseller/asmo-na/eng/index.htm http://www3.intel.com/cd/channel/reseller/asmo-na/eng/index.htm to sign up
