Server Products
4784 Discussions
S3420GPLC startproblem
hi@all,
Board: S3420GPLC
CPU: i3-530
RAM: 4*KVR1333D3E9S/2GI
PSU: bgt p6-pro 430w (ATX12V 2.2)
After Boot up nothing happen. Just LEDs blinking an Beeps after press Power On Button as long as 5 sec.
LSB
XOXXOOOO
In the Userguide > 0xF2 O O O O X X O X Signal that the operating system has switched to virtual memory mode.
What could be the problem?
Is the PSU ATX12V ver to low?
Second: the PSU runs if I press the PSU switch on the back. Thats not normal.
As I read some things I should check:
- Board BIOS ver (higher 40?)
If it is to low where can I check it on the Board without start.
regards
Daniel_O_Intel
The good news is, the BIOS version on this board will never prevent booting. Even an old BIOS will still get you video, and messages.
Each 12V rail needs a maximum of 16A - what does your power supply provide?
Edward_Z_Intel
See if it's related to this one: http://www.intel.com/support/motherboards/server/sb/CS-031225.htm TA-943: Board may not boot with certain processors or http://www.intel.com/support/motherboards/server/sb/CS-031713.htm BIOS 42 or later required to boot certain processors
