I updated the BMC to the latest version, or tried, on my S5000PSL using a DOS boot disk and the DOS Update from Intel's website. The update appears to have failed - the system will not boot in normal mode now.
If I set the BMC Force Update jumper, it will boot. I then try to reflash but no success. The Boot block and PIA appear to update just fine, but the OpCode block does not - it is always 0.00!
Updating to any version of BMC have no result on OpCode version after AC power off. During update accurs "Error 05: Update failure".
Text output of error codes are as follows:
ERROR 005: Update failure. [fwpiaupd.cpp line 831]
ERROR 009: Could not exit FW transfer mode. [fwxfer.cpp line 872]
Anyone have any ideas how to update the BMC once it reads 0.00??
You may try the BMC Force Update jumper (J1E3). See board http://www.intel.com/support/motherboards/server/s5000psl/sb/CS-022619.htm TPS section 6.2 for step-by-step instructions.
Edward,
The only way I can boot is using the BMC force update jumper but it still fails with the error as stated in the original post. Do you have any other ideas?
Remove AC
Wait 60 seconds.
try booting with out the force Jumper.
if no boot.
install jumper
boot to EFI
flash BMC in EFI
power off AC
remove jumper
apply ac
does it boot?
As long as the force BMC jumper is installed the version will read 0,00
