Ok, so I got my last issue with Grub fixed, now I have another issue, I reinstalled linux using LVM, seems once I make the LVM, and assign it a volume group and volume containers, when I reboot, at the first screen It shows me the hard drives, but once I set a LVM they go to 'disk verification failed' . Now I can boot my usb key format the drives out and it will identify them properly, I've tried different ports for the drives and no change, So I formatted them out to ext2/JFS/XFS partitions respectivly, updated to a 3.1.0 kernel and the same issue with the LVM becomes present once again even though I have not made a LVM, i reboot and voila 'hard disk verification failed' these are two brand new identical 320GB drives. I'm kinda stuck here as google gives no information on the issue, other then to 'reset the cpu's into there sockets' which I think wouldn't do a darn thing for me.
Board Identifcation
System Bios: V S5000.86B.10.00.0081
Build Date: 08/17/2007
Board Part Number: D44771-805
Board Serial Number: QSSL73201090
System Part Number: C2001
System Serial Number:A0047780
Chassis Part Number:C2001
Chassis Serial Number:C2001
BMC Firmware Revision: 0.59
HSC Firmware Revision: 0.00
SDR Revision: SDR Package 42
UUID: D3E6ED81479811DCAF6A00151730A1D4
BIOS Information
Vendor: Intel Corporation
Version: S5000.86B.10.00.0081.081720071348 <-- I updated this and it wont allow me to access it any more it drops me to efi shell =[ <p> Release Date: 08/17/2007
Address: 0xE8000
Runtime Size: 96 kB
ROM Size: 4096 kB
Characteristics:
PCI is supported
PNP is supported
BIOS is upgradeable
BIOS shadowing is allowed
Boot from CD is supported
Selectable boot is supported
EDD is supported
Print screen service is supported (int 5h)
8042 keyboard services are supported (int 9h)
Serial services are supported (int 14h)
CGA/mono video services are supported (int 10h)
ACPI is supported
USB legacy is supported
LS-120 boot is supported
ATAPI Zip drive boot is supported
BIOS boot specification is supported
Function key-initiated network boot is supported
Targeted content distribution is supported
BIOS Revision: 10.0
