Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4784 Discussions
S5000PSL ?other device, unknown device
BStev2
I'm setting up a new server with an Intel S5000PSL-R server board and have an other device, unknown device in the device manager. I tried to find out what this is but all it tells me that it is an Microsoft ACPI compliant system. Any idea's what this is, as my server is running Windows 2003 X64 with the Intel Hot-Swap drive enclosure firmwared at 2.09
Hi Serverman,
Go into the BIOS.
Go to Server Management
Disable Plug and Play Detection
Save and Exit
Restart to OS
See if it fixes it, if not, tell me the hardware id of the device, i will check it for you.
All the best,
Aryan
Hi Serverman,
Did you manage to fix it? If not, let me know the hardware id of the device from device manager. May be you can post it with a screenshot.
All the best,
Aryan
Hey Serverman!
It is important to install not only the nic drivers themself because in the driver package is also you wanted device driver included. Just install the drivers bei using the included setup and your unknown device should be gone.
Intel D915GEVL with other device, unknown device error message. Lcation n Intel(R) 82801FB LPC Interface Controller - 2640
Did driver detection, cannot find driver to make ! go away, please help. Drew
