Hello all!
I have this MB (p/n DA0T75MB6H0 Rev.H). Tested memory report notes that the maximum size of RAM is 32GB:
http://www.intel.com/content/dam/support/us/en/documents/motherboards/server/s5000vsa/sb/s5000vsa_memlist_rev_42.pdf http://www.intel.com/content/dam/support/us/en/documents/motherboards/server/s5000vsa/sb/s5000vsa_memlist_rev_42.pdf
User guide says 16:
http://www.intel.com/content/dam/support/us/en/documents/motherboards/server/s5000vsa/sb/d36977005_s5000vsa_userguide.pdf http://www.intel.com/content/dam/support/us/en/documents/motherboards/server/s5000vsa/sb/d36977005_s5000vsa_userguide.pd…
Where is the true?
Thanks!
Hello Dmitry,
Thank you for bringing this up. Let me confirm that the unit should support up to 32GB of memory. You may want to keep the following document handy.
http://www.intel.com/content/dam/support/us/en/documents/motherboards/server/s5000vsa/sb/d36978010_s5000vsa_tps_r1_9.pdf S5000VSA Technical Product Specifications
Additionally, I am adding the link for the Tested Memory List for this board. Intel always recommends using validated hardware to avoid unforeseen issues.
http://www.intel.com/content/www/us/en/support/server-products/000007244.html Tested Memory List
http://www.intel.com/content/www/us/en/support/server-products/000007244.html http://www.intel.com/content/www/us/en/support/server-products/000007244.html
Dave A
Hello Dmitry,
Dave A
