Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage; and Intel® Xeon® Processors
4502 Discussions
S5000VSA Upgrade
RGrun
Hi All,
we want to upgrade our Server with S5000VSA-Board for Windows Server 2012 R2 Essentials.
At the Moment we run Server 2003 R2, 2x Xeon 5140, and 4GB RAM.
In the different Shops they offer a lot of RAM-kits up to 32GB total.
A look in to the board-specifications says maximum RAM is limited to 16GB.
Which processor/RAM/BIOS combination offers the max. possible performance with this board?
Or better, which combination makes sence for our plans?
Thanks for your advices in advance
Roman
Daniel_O_Intel
You may run into issues finding drivers for 2012 - 2008 was the last supported OS for that board. See http://www.intel.com/support/motherboards/server/s5000vsa/sb/CS-022698.htm Intel® Server Board S5000VSA — Tested operating systems
RGrun
thanks for your answer.
I found the drivers there: https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProdId=2487 Intel® Download Center
Roman
