Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
5003 Discussions
S5000VSA sever Motherboard support NIC teaming
I am using S5000VSA Server motherboard. Want to know that it supports NIC teaming or Not. If Yes Then when can i Download the utility for the same.
Edward_Z_Intel
Yes the onboard NIC of S5000VSA does support teaming. If you're running Windows, you can download the http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18807&ProdId=2487 latest driver which includes Intel PROSet. Install by running the .bat file. If you're running Linux then you should use the bond service included in Linux, No separate utility is required. See http://www.intel.com/support/network/sb/cs-009747.htm http://www.intel.com/support/network/sb/cs-009747.htm for details about teaming.
