Server Products
4984 Discussions
S5000XVN Problems!! Help
I get S5000XVN and dont have a power supply for server, have ATX power supply and need a Power signal connector this power supply dont have, i conect all and when turn on (without Power signal conector and Temp sensor) dont see nothing in my monitor and one led turn orange ins the first led in back panel down of the keyboard (the led of the triangle with exclamation mark).
is necesary this connector Power Supply Signal Connector Pin-out (J9D1)Pin Signal Color1 SMB_CLK_ESB_FP_PWR_R Orange2 SMB_DAT_ESB_FP_PWR_R Black3 SMB_ALRT_3_ESB_R Red4 3.3 V SENSE- Yellow5 3.3 V SENSE+ Green and the temp sensor? have a form for make a replace of this?
i use a atx case.
Daniel_O_Intel
You don't need J9D1 plugged in, but you do need J9B5, J3J2, and J5A2.
Also, make sure your power supply can run up to 16A on each of the four +12V rails, 30A on the +5V rail, and 24A on the +3.3V rail.
