Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4811 Discussions
S5400SF Throttling Mode
IOgou
I'm posting this in the hopes that someone can help. I have looked through various sources online, but could find no answer or discussion, so I'll be opening it myself.
I'm not sure what all information I should start with about the server, but I'll start with the following:
Intel(R) Server Board: S5400SF
Intel(R) Server System: SR1560SF
System BIOS: S5400.86B.07.00.0033
BMC Firmware Revision: 0.11
HSC Firmware Revision: 2.09
SDR Revision: SDR Package 11
Problem:
I've been having an issue with the throttling mode. Whenever I boot, I receive a POST error, 85FC, telling me that Closed Loop Thermal Throttling could not be configured.
The most information I could find on this issue is that it may not configure properly if any installed DIMMs do not have functional AMB thermal sensors, but as far as I can tell, mine do.
I am waiting to hear back from the seller I purchased this from, but if it is possible to fix this rather than send it back and wait for a replacement (if they agree on that method), I would much rather do so.
Any help would be appreciated.
Thank you in advance.
We regret to inform you that this board has been discontinued for a while now reason why we do not offer any troubleshooting recommendations to address your issue. Thank you for your understanding.
AP16
Valued Contributor III
CLTT can be disabled in BIOS Setup, Advanced > System Acoustic and Performance Configuration. You able to get into BIOS Setup?
IOgou
I am, but I'm trying to get it to stay in CLTT. It always defaults back to OLTT due to the error.
AP16
So, what memory modules are in server?
IOgou
Reading this directly off the memory modules.
4x 1GB 2Rx8 PC2-4200F-444-11
4x 1GB 2Rx8 PC2-5300F-555-11
AP16
Well, what the CPU-Z utility shows in SPD tab?
IOgou
All modules are FB-DDR2. SPD shows bandwidth and timing data for all.
Is there anything specific I should post?
AP16
Manufacturer and PartNumber fields please. You can attach a screenshot to post.
