Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4613 Discussions
S5500BC Fan Control
MAbuc
Dear Sirs,
I have an intel server board S5500BC with latest firmware, its running normally and quite ! my problem is that my HDDs are getting hotter about 45C - 50C which isnt normal according to acronics free HD monitor tool, now is there a way i can speed up the fan behind the HDDs and the rear fan so i can drive more air inside and therefore hot air out?
Daniel_O_Intel
Not manually, no. The temperature sensors for inlet are on the front panel, so they are probably not detecting the overheating on the hard drives.
Which chassis are you using? Is it a pedestal with an 92mm fan behind the hard drive cage?
MAbuc
I'm using the Intel® Server Chassis SC5650DP that has fan the behind the HDD cage, so where are the sensors placed ?
Daniel_O_Intel
The temperature sensors for inlet are on the front panel. I don't think that backplane monitors hard drive temperature, though.
HPelt1
Hi Mabucham,
You could always try chagning some settings in the fan control menu in BIOS (change altitude, quiet to performance mode, etc.) to see what effect it has...
