Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
S5500WB PSU requirements
I have a S5500WB motherboard but nned a psu for it, I know the board is stated to require a
Intel Corp FSR1690PS 650 watt psu, I have found one but its a little out of my price range.
I also found a Delta TDPS-600CB C 600W 1U Power Supply for Intel Server SR1560SF a lot
cheaper. My questions are.
1) will it have enough power for the board?
2) If not are there any other psu that will work with this board?
Daniel_O_Intel
Comparing the power subsystem from the SR1690WB from http://www.intel.com/support/motherboards/server/s5500wb/sb/CS-030206.htm Intel� Server Board S5500WB — Technical product specification (TPS) and the power subsystem for the SR1560SF from http://www.intel.com/support/motherboards/server/s5400SF/sb/CS-028352.htm Intel� Server Board S5400SF — Technical product specification , it looks like the board may pull more amps on the +5V and +12V V1 and V2 rails than the 1560 can provide.
I would not recommend using the 1560 power supply in place of the 1690.
