After a change of a LSI 9266-8i Controller with same one, my motherboard doesn't work any more,
Have System Status LED solid amber light & ID LED solid blue light!
I cannot turn off the ID LED, I tried to clear cmos, last night I live the Server without Power, . . . .
What does it mean?
For the amber System Status Light I found:
Fatal alarm – system has failed or shut down
– CPU Missing
– Thermal Trip asserted
– Non-recoverable temperature threshold asserted
– Non-recoverable voltage threshold asserted
– Power fault/Power Control Failure
– Fan redundancy lost, insufficient system cooling. This
does not apply to non-redundant systems.
– Power supply redundancy lost insufficient system power.
This does not apply to non-redundant systems.
Note: This state also occurs when AC power is first applied to
the system. This indicates the BMC is booting.
Tried with other 100% working cpu,s
Tried the motherboard in a SC5650BRP Case, the same problem, solid System Status LED (amber) and solid ID LED (blue)
All fan's ok
All powersupplies are ok
Motherboard: S5520HC
2x Xeon L5630
Case SC5600BRP (2x750W)
Kingston RAM 6x8 GB 1333
What can I try? Or is this motherboard fault ???
Sorry for my bad english !
thanks & regards
