Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4663 Discussions
S5520HC Solid System Status LED (Amber) & solid ID LED (blue)
DMiha2
After a change of a LSI 9266-8i Controller with same one, my motherboard doesn't work any more,
Have System Status LED solid amber light & ID LED solid blue light!
I cannot turn off the ID LED, I cannot power on the system, I tried to clear cmos, last night I live the Server without Power, . . . . System_LED
What does it mean?
For the amber System Status Light I found:
Fatal alarm – system has failed or shut down
– CPU Missing
– Thermal Trip asserted
– Non-recoverable temperature threshold asserted
– Non-recoverable voltage threshold asserted
– Power fault/Power Control Failure
– Fan redundancy lost, insufficient system cooling. This
does not apply to non-redundant systems.
– Power supply redundancy lost insufficient system power.
This does not apply to non-redundant systems.
Note: This state also occurs when AC power is first applied to
the system. This indicates the BMC is booting.
Tried with other 100% working cpu,s
Tried the motherboard in a SC5650BRP Case, the same problem, solid System Status LED (amber) and solid ID LED (blue)
All fan's ok
All powersupplies are ok
Motherboard: S5520HC
2x Xeon L5630
Case SC5600BRP (2x750W)
Kingston RAM 6x8 GB 1333
What can I try? Or is this motherboard fault ???
Sorry for my bad english !
thanks & regards
Edward_Z_Intel
Remove the add-in controller and try to boot the server with minimal configuration (one CPU, one DIMM). If the server can boot, add the components one at a time. If it doesn't boot, check the POST Code LEDs on the back of the board. See Appendix E of the board http://www.intel.com/support/motherboards/server/s5520hc/sb/CS-030223.htm Technical product specification for more details about POST Code LEDs.
DMiha2
Hi!
Thanks for your answer.
I tired also with Minimum configuration,
I tried without any Controller Card, only the Board, changed CPUs, changed RAM anf the CASE with Power Supplies,., nothing helps.
All other components work, have here more S5520HC/SC Servers.
I cannot Check the Post Code LEDs, the System doesn't power on.
Have only System Status LED solid amber light & ID LED solid blue light!
Motherboard will be exchanged (warranty)
thanks
ahoxh
Hi
i have the same issue last days.
How did you managed the situation?
Did you change the board?
