Server Products
4956 Discussions
S5520HCT and Win 2008 R2 Hyper-V
Hi all,
We have 3 servers with this board in an intel SC5600LX chassie. When we add the roll Hyper-V the network performance drops by an order of 10.
What we have done;
Install Windows 2008 R2 run all updates
test speed and get ~100M
Add Hyper-V roll and reboot
Test speed and get ~5M
Remove Hyper-V and reboot
Test speed and get ~100M
Readd Hyper-V
Turn off all offload settings in NIC Card settings
Turn off in Netsh
Play with buffers
Use both Microsoft provided NIC drivers and latest Intel drivers
Added 4 port Intel I340-T4
Allways same result.
Any ideas please?
Daniel_O_Intel
Press F2 during POST->BIOS setup pageà Advanced-> Processor Configuration -> set Intel(R) VT for Directed I/O Enable; set Coherency Support Enable; set ATS Support Enable; set Pass-through DMA Support Enable.
Hi Dan_O,
Thanks, that seems to have done the trick.Microsoft support had disabl;e the driver called passthruparser - so these setting effect this driver.
set Intel(R) VT for Directed I/O Enable - This was enabled
set Coherency Support Enable - This was not
set ATS Support Enable - this was not
set Pass-through DMA Support Enable - this was not
We will test this against the other two systems we have and advise.
Thanks again Dan_O
Hi Dan_O,
After some more testing I found that I still had two drivers for Hyper-V disbale.
After reenabling the drivers the problem still happen enevwith the bios setting turned on.
Any other ideas?
JasonT_Intel
Can you try Enabling the option of Maximize Memory below 4GB under BIOS, you can find this under Advanced-> PCI Configuration -> Maximize Memory below 4GB (default is Disabled). See if it helps.
JasonT_Intel
Intel just released a notification that a potential BIOS update may fix this issue. Will keep you posted once we get the official BIOS package.
