I have an S5520SC Motherboard which I have tried using with a variety of SSD drives. However when I do I get a 1-2 second lag every time I go to do something. Please help!
Hmmm,
Intel support has this to say:
1) Windows 7 is not a supported Operating system for S5520SC workstation. Please refer to the URL for the list of supported operating system
http://www.intel.com/support/motherboards/server/s5520sc/sb/CS-030230.htm http://www.intel.com/support/motherboards/server/s5520sc/sb/CS-030230.htm.
2) Further, Intel X-25M solid state drive is not a validated harddisk for S5520SC workstation, please refer to the URL for the list of supported harddisk:
http://serverconfigurator.intel.com/configure-ap.aspx?id=MTY2NiMxLDI1MjAjMSwyNjE5IzIsMjUzMiMx http://serverconfigurator.intel.com/configure-ap.aspx?id=MTY2NiMxLDI1MjAjMSwyNjE5IzIsMjUzMiMx
Does this seem like a reasonable response?
As mentioned on another thread, your problem may be worked around by plugging both NIC ports into your network.
Cheers hypermeta,
It's a bit mad though isn't it? Such a oblique solution to a fairly major problem!
as mentioned in another thread updating the LAN drivers will fix the problem - i had the same problem and it was fixed through updating....
