I have at home a S5520UR server, the frontal led in bliking and seems to be a ECC-memory module that is wrong.
I have download the PCT for EFI, copy it to a USB and follow instructions.
But when I click on "quick test" or "comprehensive test" an error is shown and no test is done:
*** ERROR TX64.EFI 3.15.1.0001 ***
Missing or invalid software license.
Standard Error Code = 3060092F
(Error logged at 12-03-2015 20:20:05)
I have search but I have not found any reason.
Does some know the reason of the error? or a way to solve it?
Or, is another way to identify the wrong memory module?
I will appreciate any help.
Thanks a lot
We regret to inform you that the board you are looking support for has been discontinued but as a general recommendation try running the Intel System Information Retrieval Utility instead:
https://downloadcenter.intel.com/download/19657/Intel-System-Information-Retrieval-Utility-sysinfo-For-UEFI Download Intel System Information Retrieval Utility (sysinfo) For UEFI
I have the same problem with the S2600CP4 board.
I do not understand further available tests for older products do not work ...
