Server Products
4778 Discussions
SE7501HG2 board will not POST
Board is mounted in a SC5200 chassis. When powered on it shows the bios for the Rage XL card, shows Lan Boot Agent. Freezes after that with a blinking cursor.. If I try to PXE boot, it shows MAC address, no DHCP and then goes to a blinking cursor. Have tried all available bios available through Intel, Recovery appears to work and I get two beeps at the end of recovery, All hardware is disconnected, have tried changing RAM and Processor. Any thoughts?
Will it boot to a bootable floppy or CD-ROM?
John
No. I have tried reinstalling the BMC, FDU ect by modified floppy but nothing works. The screen is off during bios recovery so no way to boot to an operating system or emergency disk. Now the lights on the fans are on. I think I've got a toasted M/B.
Figured out that reinstalling two pci cards back into the server and it posted. If I remove the cards, it fails. I would like to remove these cards (Dialogic) as they are not needed anymore. What could be causing the system not to post without the cards installed?
That is a strange one. Usually it's the other way around. You may want to reset the BIOS to factory defaults. If you can't do that from the BIOS, remove the CMOS battery for 10 minutes so so to reset the BIOS.
John
Already tried all of that. Tried pulling card with server running and update the bios. No dice. Server will not boot to bios with out the card installed. Operates perfectly with card installed. Doesn't matter what slot it's installed in. Almost like Dialogic installed a pre-boot pxe code or something.
Seems like your BIOS recovery and booting to a floppy should have gotten around that. I don't know what to tell you. I haven't heard of anything like this. But I also haven't had much, if any, experience with Dialogic cards.
John
Daniel_O_Intel
Here's an oddball thought, if the SE7501HG2 isn't putting enough draw on the 5V rail to start up the power supply. The Dialogic cards were pretty heavy users of the +5V rail, if I remember correctly.
Before you try replacing the motherboard, have you tried a different power supply?
