Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
SM Bus issue
RKhan15
Hi
  I am using S2600WF and we have a PCIe Add in card on the riser card in the server. We are trying to enumerate our SMbus device using the i2c_connect tool running in CentOS7.8.  When we run the i2c tool it only shows the controllers on the system. We have probes on our Add in card's SMbus pins. We don't see any activity on the SMbus to our card in the PCIe slot when we run the I2C connect tool. Question is do we need to enable something in the BIOS to enable SMBus to our Add in PCIe card?
thanks
SergioS_Intel
Hello RKhan15,
Thank you for contacting Intel Customer Support.
Can you please share with us the model of the PCIe Add in card that you are using?
Also, did you check if the Add in card is properly working?
Sergio S.
For firmware updates and troubleshooting tips, visit :https://intel.com/support/serverbios
