Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4663 Discussions
SNMP Sub-Agent for Windows creates unending log files
JCook12
We have installed the SNMP Sub-Agent 6.0.11 on to Servers using the Intel Server System P4000IP and running Windows Server 2012 R2
The agent is working fine and we can use SNMP GET to interrogate the baseboard hardware. However it is creating a huge amount of log files labelled CacheRiver under C:\root\crlogs
We have tried getting access to this folder, deleting the logs, setting it so Administrator does not have write permissions and restarting SNMP service. This stops the logs, but then the SNMP service will slowly incease in memory usage until it causes an issue.
How can we stop the log files from being created?
Justin
Daniel_O_Intel
I see there was a similar issue three and a half years ago at , but I don't see any update since then.
Let me ask around and see what i can find.
THeap
Hi
I have noticed this problem on a number of installations, on varying platforms.
To date I have not found any solutions other than flushing logs regularly.
The only way to stop the logs at the moment is to remove the Sub-Agent.
Any info would be helpful.
Rgds Tony
Daniel_O_Intel
Tony -
This version https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=24008 Intel® Download Center is supposed to have the fix. Can you test it out?
