Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4784 Discussions
SR1550AL running with 2 core problem
sboyn
I had installed centos 6.4 to SR1550AL system with one CPU, but I got second CPU's fan today and tried to run server with two core but gives first green blink at status led and goes to power led to sleep(repeated too many times) then I had resetted CMOS after that status led amber on power led staying at green but no bios, what should I do?
Daniel_O_Intel
Try going back to just one processor. Do the POST code LEDs give you any indication of where, in the boot process, the board is stopping?
sboyn
(ONE) CPU is running at the first start:
A: is off
B: is green on
C: is green on
after a while(at the time normally gives BIOS at the screen) :
A: is off
B: is amber on
C: is green on
when pussh power of:
A: is off
B: is amber on
C: is green off
(TWO) CPU is running at the first start:
A: is off
B: is green blinking
C: is green on
after a while
A: is off
C: is green off
after a while
A: is off
C: is green on
after a while
A: is off
C: is green off
A: is off
C: is green off
after a while
A: is off
B: is amber on
C: is green off
Before I used second CPU system was working with OS very good... After using second CPU now nothing working, no BIOS no OS..
sboyn
This is very important for me, but no enough paper, no enough help why do I buyed intel server?
sboyn
Next question, how can I reset CPU' s fan power or how can I make it auto setup. Because I think there is a power problem on board? when 2 core running power became on and off repeadly...
Daniel_O_Intel
I meant the LEDs on the back of the chassis, here
Since it works fine going back to a single processor, can you verify that the two processors have the same markings on them?
sboyn
Post Code Leds for "A" area from left to right: 1. OFF 2. YELLOW 3. YELLOW 4. RED
B: OFF
C: YELLOW
K: OFF
L: OFF
M: OFF
N: GREEN
Any clue?
sboyn
Post Code leds detailed:
I am working on two servers now
first one has two progresser and their mark:
INTEL06 E5440
INTEL XEON
SLANG COSTA RICA
2.83 GHZ/12M/1333
Post code Leds(A) action for first server(FROM LEFT TO RIGHT):
when AC Power plugged:
GREEN RED OFF OFF (just blink), after a while goes all of them off and when Power on(FROM LEFT TO RIGHT):
OFF OFF OFF OFF (NO ACTION)
after a little time Power goes off and status became amber.
Second server has two progresser too their mark:
2.33GHZ/4M/1333/LV
INTEL XEON
S148 SL9RR COSTA RICA
i 05
Post code Leds(A) action for second server (FROM LEFT TO RIGHT):
GREEN RED OFF OFF, after a while goes all of them off and when Power on(FROM LEFT TO RIGHT):
RED RED OFF RED after a while
RED YELLOW GREEN RED (3 bips cames) after a while
OFF YELLOW YELLOW RED
This is detailed post code leds status of our devices, please quick help...
sboyn
Daniel_O_Intel
SLANG shows as an E5205 on ARK
http://ark.intel.com/search?q=SLANG http://ark.intel.com/search?q=SLANG
Do you mean the first board has one E5440, and one E5205?
If so, mixing processors isn't a good idea.
If that is one processor, marked SLANG *and* also marked as an E5440, then there is a problem, and it may not be a genuine Intel processor.
That one is also a 45nm processor, which means it does require a board with revision level D13607-903 or thereabouts. what is the board revision that you have?
The second one, SL9RR, does match up to an LV 5148 on ARK
http://ark.intel.com/search?q=SL9RR http://ark.intel.com/search?q=SL9RR
Does that server have just one processor, or two?
sboyn
it is not http://ark.intel.com/search?q=SLANG http://ark.intel.com/search?q=SLANG,different. I have two boards and each one of them has 2 CPU, and one board has two CPU marked:
2.33GHZ/4M/1333/LV
INTEL XEON
i 05
other one has two CPU marked:
INTEL06 E5440
INTEL XEON
SLANG COSTA RICA
2.83 GHZ/12M/1333
also SLANG marked E5440 was worked with SR1550AL board very good with one CPU until I got seconds new CPU's. Firstly I mixed them with out any known but after that I had recognized the problem and sapareted them, however after that point no CPU is works.. The even not works.. no clearence of BIOS also didnt work. I need to know how to decode post code leds..
Edward_Z_Intel
Is it possible that your E5440 processor is SLANS instead of SLANG?
I would suggest you first try each of the processors one by one in slot 1 to make sure they're working.
To decode the POST code, refer to the http://www.intel.com/support/motherboards/server/s5000pal/sb/CS-022640.htm Intel® Server Board S5000PAL technical product specification, Appendix C.
sboyn
Yes it is SLANS edwardzh, could you help me to identfy problem..
sboyn
News,
2.33GHZ/4M/1333/LV
INTEL XEON
(NOT S148)5148 SL9RR COSTA RICA
i 05
with 2 core finally worked, but
INTEL E5440
INTEL XEON
(NOT SLANG)SLANS COSTA RICA
2.83 GHZ/12M/1333
Either one or two progresser aren't working.. even boards power led not responsing however fans are working.. what can be the problem?
sboyn
so is this says INTEL E5440 is not going to work?
Daniel_O_Intel
The Intel E5440 will work, but it does require a board with revision level D13607-903 or thereabouts.
There should be a white sticker on that server board, that has the serial number, the letters, "PBA", then a number of the pattern "D12345-678". What is that PBA number on the board that you have?
sboyn
Yes there is a stiker on board like you said:
PBA D13607-804
Daniel_O_Intel
Referencing http://www.intel.com/support/motherboards/server/sb/CS-028540.htm http://www.intel.com/support/motherboards/server/sb/CS-028540.htm :
Intel® Xeon® processors 5400 and 5200 series require specific hardware and software revisions
S5000PALR
891957
D13607-902 or later
The E5440 will not work on a board that is D13607-804, I am sorry to say. However, the 5148 processor does not have such a limitation.
Are both boards of the -804 revision, or is one of them a -903 revision?
sboyn
Both boards are -804 .. So I am going to buy new proccessors for 804 board, could you suggestion me best suitable proccessor (like 4 core or 8 core) for 804 board, and I need to buy a board for E5440 proccessors any suggestion too? Thank you.
Edward_Z_Intel
See http://www.intel.com/support/motherboards/server/sb/CS-022346.htm Tested processor list. Xeon Processor 5200 and 5400 series are not supported on -804 board. Other CPUs in the list are supported.
sboyn
Is best option for 804 this one?
CPU NumbersSpec NumberCore SpeedBus SpeedL2 Cache SizeCore StepWattage (TDP4)Notes (below)X5365SLEAD3.00GHz1333 MHz8 MBG0
Note proccessor list :
http://www.intel.com/support/motherboards/server/sb/CS-022346.htm# 5400 Intel� Server Boards — Tested processor list
