Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4617 Discussions
SR1625UR SAS 2 Server
What parts (numbers) do I need with the SR1625UR system and a RS2BL080 raid card to achieve the SAS 2 (6 Gb/s)? I will be installing 5 Savvio 15.2 drives in a raid 10 setup (1 will be hot-swap).
Paul
Edward_Z_Intel
I'm afraid the SR1625UR midplane supports 3Gbps data transfer only
Does the SR2625 support 6 Gb/s? If so, is it a passive or active riser? What part number?
Paul
Daniel_O_Intel
Currently, only the Intel pedestal non-expander backplanes support 6Gb/s data transfer
