Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4613 Discussions
SR1690WB driver
LEmal
Hi to everybody,
I've a system SR1690WBR (Main board S550WB with FUP BIOS60_BMC58_FRUSDR16 HSC 2.15).
I've Raid 5 with 4 hdd (with axxraksw5) and iI try to install Windows Server 2008 R2 with driver ESRT2_Windows_v.14.05.0727.2011.zip (mb has only sata ctrl no sas ctrl).
O.S. report no volume drive to install.
I've already try:
downgrade bios to v59
install on raid 1 with only 2 hdd without axxraksw5
I've try to change mb.
I've try to use driver ESRT2_Windows_v.13.21.0614.2010
Have you some suggestions?
Edward_Z_Intel
What HDD are you using? Is the RAID 5 volume larger than 2TB?
LEmal
Solved.
I've changed type of hdd.
The problem is only with hdd Seagate 500GB SV35.5 ST3500411SV firmware DV15.
I've change hdd with WD 500GB Raid edition.
