Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4663 Discussions
SR2625urlxr power supply fan always On
kdy
Is the power supply fan on SR2625urlxr always on even if the server is shutdown?
DSilv11
Valued Contributor III
Yes. The power supply is providing stand-by voltage to the BMC and wake on lan functionally even when the server is "off"
This is one reason you should always remove the AC cord when working in side the chassis as some area are always powered.
