Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage; and Intel® Xeon® Processors
4466 Discussions
SRCSATAWB max disk size
Community Manager
when will the SRCSATAWB RAID controller support large capacity harddisks, like 3TB disks? Hope to hear from you.
regards
Edward_Z_Intel
I'm afraid no - the SRCSATAWB uses LSI* 1078 SAS ROC, which doesn't support physical drives larger than 2TB. It's highly recommended that you select drives from the http://www.intel.com/support/motherboards/server/srcsatawb/sb/CS-028320.htm Tested hardware and operating system list. There are 2TB drives in the list.
Community Manager
Hello Edward,
thanks for the reply. The card is allready full with 2TB disks, that's why we want to upgrade to 3TB. So there's no upgrade for this card in the future due to the physical limitations? So we should get another RAID controller then?
regards
