Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage; and Intel® Xeon® Processors
4482 Discussions
SS4000E failed after power failure.
amert2
It says system degraded and all the hard disk lights on the front are red. How can I locate which disk failed. I have a little bit unix experience. I mainly use windows. Since it is degraded, I should be able to recover the files or copy of them if I can bring the system back.
Dashboard
Free0 B
Used0 B
Backup0 BTotal Space0 B
05/31/2015 7:32 pm
https://192.168.0.6/dash-dev.html?t=2
https://192.168.0.6/dash-dev.html?t=2 4 disks on your storage device have incorrect data on them. Data on the storage device is available but may be lost if another disk fails. Click here for more details.
https://192.168.0.6/dash-pphl.html?t=2
https://192.168.0.6/dash-pphl.html?t=2 No peripherals are currently attached to your storage device.
https://192.168.0.6/stg-backup.html?t=2
https://192.168.0.6/stg-backup.html?t=2 All backup functions are operating normally.
storage Status
Descriptive Name:Intel Entry Storage System Device
Model Name:SS4200-E
Serial Number:00151731CCF7
Software Version:1.1.11.32736
<label class="label...
David_A_Intel
The description of the issue is very similar to a http://www.intel.com/support/motherboards/server/ss4000-e/sb/CS-033844.htm Loss of System Access Issue. You may also shutdown the unit, remove all drives, and power on the system to boot to its local firmware, once you have access to the GUI you insert one drive at the time to see if it can read the drive properly. This is to eliminate the chance of a multiple drive failure.
amert2
Thanks David. If I remove all the drives and put it back one by one in the same location do I loose the data on the disks or not. I have Intel Entry Storage Manager Software which is web based and do not show Advance tabs etc. Where can I get the software with GUI.
amert2
David_A_Intel
amert2
amert2
