Hi
I´m still using an SS4000-E nas and i want to use raid 1 but in 2 "pairs" so disc 1+2 is one raid 1 and diskc 3+4 is another raid 1 - but i can´t get it funktion !.
I´ll not use raid 10 if that means data is spread between the disc´s , If the nas goes down , it would be much easier to get the data - even if one of the disc is bad!.Newer nas can run several raid 1 - is it not possible with SS4000-E ????
Thanks in advance
- Tags:
- RAID
Jan,
The SS4000 supports RAID levels 0, 1, 5 and 10. You can use RAID 1 if your storage system has only two disks. You can use RAID 10 if your storage system has four disks. There is no capability for two sets of RAID 1.
John
Topic Options
