It's my understanding that the S2600IP4 is used only with Intel cases, so my pre-integrated bare-bones server combination should have had a reasonable fan profile out-of-the-box.
But it doesn't. The fans run at full screaming velocity. It's louder by itself than our entire colo facility. The sound goes right through the heavy server-room door.
Below is the sysinfo output. One thing that's concerning is that it lists CFM at 0. I can see that with ipmitool as well. Is this sensor (and how does it work?) part of the fan control? Is it broken? I've tried all the different dynamic and static open and closed loop acoustic management options in the BIOS. Nothing helps. I've put in all the FW updates.
sysinfo_log.txt: http://pastebin.com/R6rFHEbb http://pastebin.com/R6rFHEbb
Here is the configuration. It runs CentOS 6.3 but even in the BIOS or EFI shell the fans are screaming at some emergency warp factor.
http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=16911489 http://secure.newegg.com/WishList/PublicWishDetail.aspx?WishListNumber=16911489
I guess I need some FRUSDR magic ... where do I start?
The sysinfo_log.txt file says you have SDR Package D1.03, which doesn't seem right... The latest https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=22692&lang=eng Firmware update packagehas FRUSDR 1.09.
Can you try to apply FRUSDR again? During the FRUSDR update, check if your chassis model is correctly detected.
And that was it. (Yay! Fixed! Quiet server!) When I was updating, the BIOS, BMC, and ME firmware all installed automatically. But the FRUSDR update asked an interactive question. I kept saying "no," thinking that it had finished the automatic part of the update.
