Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4808 Discussions
Searching driver for device VEN_8086&DEV_0998
AlexKZ
Hello I need help installing the driver. In Device Manager the driver is installed and the device is named Standard CPU-PCI Master Bridge. Device ID VEN_8086&DEV_0998. What it is? Google didn't help. Please help.
Allan_A_Intel
Hello, AlexKZ,
Thank you for reaching Intel Communities. I will gladly help you.
It seems that the driver you need is related to Sapphire Rapids systems. Please let me know what is the brand and model of your motherboard and of your processor, and what is your operating system. Also, please explain why you need to install that driver.
Allan
AlexKZ
Some people have a theory that there should be no devices with the name "Standard..." in the system
AlexKZ
Hello Allan, motherboard from HP ProLiant DL360 Gen10 Plus server, Intel(R) Xeon(R) Gold 6346 CPU @ 3.10GHz, MS Windows Server 2016-2022 operating system version (I tried on all)
Allan_A_Intel
Hello, AlexKZ,
Thank you for the information. Supported operating systems are not defined by the Intel® Xeon® processor or a server's chipset, but it is dependent on the operating systems supported by the server motherboard or system. The motherboard or system manufacturer will validate certain operating systems with the motherboard or system and provide drivers for the supported operating systems.
Contact your server system or motherboard manufacturer for OS compatibility and for drivers information. If you encounter issues when using one of the OEM's supported operating systems, ensure that you have the latest BIOS firmware and drivers installed from the OEM: https://www.intel.com/content/www/us/en/support/contact-intel.html?tab=system-manufacturers
Allan
