Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4653 Discussions
Second Modular Server MFSYS25 as spare parts container
One of my clients considers buying two identical MFSYS chassis. Then to remove:
- SAS Storage Control Module
- Gigabit Switch Ethenet
- 2xAC power adapters
from the second chassis and put in into the first (as a backup/additional modules).
The second chassis one will be kept as a backup in case the first stops working.
Will it work ? Could primary modules included with the chassis work as addional modules in another ?
greetings
Mike
Edward_Z_Intel
Yes.
The second SCM gives you redundant SAS connection. But MPIO driver needs to be installed on your OS. See http://www.intel.com/support/motherboards/server/sb/CS-029441.htm Special instructions for installing dual Storage Control Modules for details.
With the second ESM, you can connect your compute modules to two seperate physical networks, or you may configure SFT (Switch Fault Tolerance) teaming for redundancy.
Yes, and this can be a much cheaper way to go if you want all the modules, just beware there is also now a MFSYS25V2 which uses a new backplane and management module, and different version of the firmware than the older MFSYS25.
Edward_Z_Intel
Btw please take note that one Dual Gigabit Ethernet I/O Expansion Mezzanine Card AXXGBIOMEZ is required for each compute module that needs to access the second switch. See http://www.intel.com/support/motherboards/server/mfsys25/sb/CS-028603.htm FAQs about the Intel® Gigabit Ethernet Switch AXXSW1GB for details.
