Dear all:
We found another strange problem. After updating the whole firmware completely,from the BMC Web we can check that the "exit air temp" sensor had output data, but when the server lost power supply and restarted power again, the "exit air temp" sensor status showed Unknown, and the fan speed was not normal.
Server Board is S2600BPS and S2600BPB
Hello Du Yu,
Can you please download and run the System Information Retrieval Utility (SysInfo) and attach a copy to this thread?
Additionally, please let us know what firmware version did you install?
Sergio S.
A Contingent Worker at Intel
For firmware updates and troubleshooting tips, visit :https://intel.com/support/serverbios
Hello Du Yu,
I am following your question and we would like to know if you were able to download and run the System Information Retrieval Utility (SysInfo) and get the BIOS version of your board.
Sergio S.
Through the test;
Restore the BIOS default settings by setting BIOS default pin on the motherboard-S2600BP, then connect the AC power for the first time, log in the BMC web interface and find that the exit air temp has data. But the second time AC power was connected, exit air temp displays unknown.
Why is the result different after resetting BIOS, disconnecting AC twice and reconnecting?
Hello Du Yu,
Thank you for the information, we are going to check the logs and get back to you.
Sergio S.
Hello DuYU,
Since the issue started after the update, please try the latest firmware release 02.01.0009.
https://downloadcenter.intel.com/download/29109/Intel-Server-Board-S2600BP-Family-BIOS-and-Firmware-Update-Package-for-UEFI?product=93091
Regards.
Sergio S.
Hello DuYU,
I am following your question and we would like to know if you need further assistance.
Sergio S.
Hello DuYU,
Sergio S.
Hello DuYU,
Sergio S.
Sensor "exit air temp" status was still unknown after latest firmware release 02.01.0009. had updated.
CPU is Xeon Silver 4214 *2
Hello Duyu,
Thank you for the information.
Please try to clear the CMOS of your system, refer to the Technical Product Specification on page 86
Clearing and resetting the server board CMOS is required after every processor configuration change. Clear-ing and resetting the CMOS is achieved by setting the “BIOS DEFAULT” jumper on the server board. See Chapter 8, Configuration and recovery jumpers.
Page 144.
Additionally, please try to load the BIOS default settings.
Sergio S.
Hello Duyu,
We tried to open the zip file; however, is requesting a password, can you please provide to us the password for the file or send it without the password?
Sergio S.
Intel S2600BP automatically encrypts the log when exporting it from BMC WEBUI. We don't know the password.
Hello Duyu,
Thank you for the information we are going to check with upper-level support on this case.
Sergio S.
Hello Duyu,
Can you please provide us the sys.logs with the latest version BIOS?
Sergio S.
Hello Duyu,
We were wondering if you were able to get the sys.logs with the latest version BIOS, so we can assist further.
Sergio S.
Hello Duyu,
Sergio S.
Hello Duyu,
In case you need further assistance please contact us back.
Sergio S.
