Server Products
Data Center Products including boards, integrated systems, Intel® Xeon® Processors, RAID Storage, and Intel® Xeon® Processors
4554 Discussions
Server 2008 R2
CBohl1
Hi I have just migrated to R2 and I am having an issue with my Team.
I can create a team and set a static IP address and all goes well.
I issue is when I restart my DC which is where this team is configured DNS does service does not start.
I get the following error in the event log.
The DNS Server service terminated with the following error:
The network is not present or not started.
Now I assume this is because the team is not initalized when the service attempts to start.
This Did function correctly using server 2008.
I am using a S5000VSA server board with the latest bios version 98.
I have had a mental breakdown trying to resolve this so your help will be appreciated.
Chris
Daniel_O_Intel
I see a few issues with teaming and R2 at /message/62326# 62326 http://communities.intel.com/message/62326# 62326 . Does it function properly, if not teamed anymore?
CBohl1
Hi Dan_O,
At the moment I am using one onf the nics only and it works fine.
I was wondering if there was a way to get the team to start sonner to see if that fixes the issue.
The other thing is the driver I have for Intel website does not state 2008 R3 I can see windows 7.
Could this be the issue?
KAMALANATH_N_Intel
/message/69009# 69009 http://communities.intel.com/message/69009# 69009
please refer this above link
KAMALANATH_N_Intel
may be this link helps you.
kamal.
CBohl1
Hi Dan
Mate I followed that link you provided and came across the latest driver for Windows 7 /2008 R2 x64 and problem is resolved.
Mavric
Daniel_O_Intel
Glad to hear the problem is solved!
